Transmission Removal Problems...
I couldn't get my transmission to move back either the first I tried when I recently removed my transmission. I had not removed the driverside bolt along the top of the transmission bell housing after I had lowered the engine.
I agree check that you have loosened the upper starter bolt. If you have you will know how difficult it was to see. If you are 100% sure all the bots are out and the fork is pulled there is a notch to insert a very large screwdriver and seperate the flanges. Do you have any space or is it tight between the trans and the block?
thanks for all the replys guys... i will be going out and checking your theories tomorrow after I get off of work... i am positive i pulled all the bolts that encircle the bell housing and hold the trans to the engine... i remember pulling the upper started bolt but now after reading all these posts that suggest how easy it is to mistake the upper for the lower i am suspicious that may well be my problem. there is no gap between the engine / trans right now... if i place a screwdriver in that lower notch and pry VERY SLIGHTLY I can make a 1/8th inch gap along the bottom and it feels as if the hang up is a bolt or blockage along the top side of where the engine and trans connect... would this be consistent with the upper started bolt not being removed? Thanks again for all the help!
Originally Posted by ohhhdang' date='Mar 16 2007, 02:34 PM
did you disconnect the driveshaft bolts? (i know its a stupid question but you never know)
