Transmission Removal Problems...
Old Mar 17, 2007 | 04:25 PM
  #31
TheCarGuy2021's Avatar
Oh well. Old clutch is off, really about nothing left on the disk.
Old Mar 18, 2007 | 08:28 AM
  #32
RedY2KS2k's Avatar
I removed the upper starter bolt. It was easy to put back in. I took one of those flexible picker-upper thingies with the fingers/claws on the end. I gripped the hex head with the fingers, and was able to screw the bolt in finger-tight that way.
If you've got one of these things, give it a try. It might save you a couple of minutes.
Old Mar 18, 2007 | 08:53 AM
  #33
Anyone know the torque specs for the exedy hyper single pressure plate bolts? Same as OEM?
Old Mar 18, 2007 | 11:57 AM
  #34
SPECIAL-OPS-S2K's Avatar
just bumping this back up to the top... I am pulling my clutch/pp out right now and the bolts holding the pp down look different than ones I have seen before... this is prob. a stupid question but you guys know everything soooooo... what size are they and do I need a special socket to remove them? Thanks so much!
Old Mar 18, 2007 | 12:14 PM
  #35
Stratocaster's Avatar
You need a 12 point socket. It is not special, it is common.
Old Mar 18, 2007 | 12:40 PM
  #36
thanks! and in case anyone else has the same question... it was a 10mm 12 point that did the job!
Old Mar 18, 2007 | 05:32 PM
  #37
If only the exedy PP bolts were 10mm. I had to go get a special hex socket in order to torque them down.
Old Mar 19, 2007 | 06:43 PM
  #38
UPDATE I HAVE THE TRANSMISSION OUT AND NOW AM NOT SURE HOW TO REMOVE THE STOCK FLYWHEEL AS I DO NOT HAVE THE $100 RING GEAR HOLDER TOOL THAT HONDA CALLS FOR... WHAT DO YOU GUYS USE?
Old Mar 19, 2007 | 06:44 PM
  #39
oops sorry for the all caps post... CAPSLOCK was on! lol
Old Mar 19, 2007 | 06:53 PM
  #40
Slows2k's Avatar
An impact wrench is all you need
