Transmission Removal Problems...
update... you guys are awesome!!! Much thanks to everyone that posted info here... I pulled the tranny last night and it was just as many of you thought! I checked the things you posted and it was the upper starter bolt that needed to be removed... once i pulled that bolt i was able to slide the tranny off with no issues whatsoever! excellent info saved me alot of messing around!
Anyone ever do a synchro in an S2000. My 1-2 grinds every once in awhile and it could be a problem after this autox season. I have taken down and put back together a couple manuals but just wondering how hard this one is?
Wow, I'm on the same step right now! The transmission is on a jack stand right now waiting for me to pull it out. I didn't have too much of a problem with the starter bolt, it was just a PITA to find it (putting it in is going to not be fun either). This is a big job! (had to remove entire S/C unit too) Well, time to get back at it!
Wish me luck!
Wish me luck!
Wish me luck!
Wish me luck!
Originally Posted by milkbubble' date='Mar 17 2007, 03:01 PM
When i swapped my clutch i didnt take the upper starter bolt out all the way. I backed it out enough and left it resting inside.. that saved alot of time as well.
SAME... I left the bolt there for easy re-installation!
