Trouble getting into 1st & reverse (and with my CAPSLOCK key)
Old Jul 14, 2013 | 01:28 PM
sam i am's Avatar
Default Trouble getting into 1st & reverse (and with my CAPSLOCK key)
Im having a couple of problems. I cannot put my car into reverse. I've put some muscle into it and wouldn't budge. I could push it down and move it right, but it wouldn't pull back. The other problem is shifting to first gear. First is the toughest gear to shift into. It's as if I have to jiggle it into place. Other than that, shifting between 1-2, 2-3, 3-4, 4-5, 5-6 is easier, but still not normal.
Anyone know what is wrong, and if so what is a solution?
Old Jul 14, 2013 | 04:27 PM
drobinson1692's Avatar
Test
1. turn off car - can you shift then? If no, then it's tranny related.
2. hows your clutch pedal feel? if you can shift with car off, clutch is probably not disengaging/is dragging. Clutch bleed and pedal rod will probably need to be adjusted.
Old Jul 14, 2013 | 07:43 PM
99SH's Avatar
Check fork travel, may be issue with hydraulics.
Old Jul 14, 2013 | 10:00 PM
superstuddc27's Avatar
Test
+1
It's not your tranny if you can shift through all the gears when the car is off. If it's an issue only when the car is on (as I have experienced before) then it is clutch or clutch related. it is either your clutch and/or clutch assembly or your clutch hydraulics and you may need to bleed or adjust it.
I had an issue with my mustang gt being really difficult shifting into first and then that progressed to all the other gears eventually and i ended up needing a new clutch. Brand new clutch fixed the problem immediately. That was one experience where i needed a new clutch but the clutch was not slipping.
Old Jul 15, 2013 | 07:29 PM
sam i am's Avatar
I can shift through gears when my car is off. Its not perfectly smooth it is a little clicky.
Old Jul 15, 2013 | 07:50 PM
BLAQ&GREYs2k's Avatar
It shouldnt matter whether the car is on or off. A manual transmission is simply a gear box full of oil. Your clutch is not disengaging enough to allow the syncros to let go of the current gear and move into another. Does the pedal feel softer than usual? I had this issue as have many members here in the past. The master cylinder for the clutch goes out. On occasion the slave cylinder as well. Those are the only two parts associated with releasing the clutch and allowing you to smoothly change gears.
As another test for you, get 2 quarts of HONDA MTF fluid and change the manual trans fluid. Check for any shards of metal...
Old Jul 16, 2013 | 11:50 AM
sam i am's Avatar
Well, my clutch pedal does feel a bit softer. If I push it with my thumb, I can get it about 80% of the way down. The other 20% is more resistant and I have to use my foot. Some other problems I have noticed are the leak behind my clutch pedal (im guessing thats the master cylinder?). SO do you think the problem is with the clutch not disengaging enough to shift to the next gear smoothly?
Old Jul 16, 2013 | 12:53 PM
jimboslice's Avatar
That's your problem right there. There isn't enough hydraulic pressure in the system to fully disengage the clutch. I'd suggest replacing the cmc and slave.
Ninja edit: FIRST check what your fluid level is before spending money on parts. If it's low because of the leak, replace the fluid and see what happens.
Old Jul 16, 2013 | 02:18 PM
Originally Posted by jimboslice
Originally Posted by sam i am' timestamp='1374004241' post='22669573
[quote name='BLAQ&GREYs2k' timestamp='1373946605' post='22668156']
[/quote]
yep thats your problem. Replace the MC and slave cylinder while you are at it. Takes about an hour
hyperkin
Mar 21, 2010 11:26 AM
DOHC_Side
36
Jun 1, 2009 03:54 PM
Blackx2
Jan 22, 2008 09:56 AM
jal3lee
Nov 25, 2005 09:11 AM
FormerH22a4
Jun 11, 2003 04:11 PM
