A Tune Up
Without knowing the mileage on your car, some of the following are guesses.
You really don't "tune" this engine. You do maintenance on it in hopes of bringing back the original performance.
-air filter
-injector cleaner
-new spark plugs, even though the stock ones are good for well over 100K.
-clean area at the throttle body
-check PCV valve and replace as necessary
-Valve adjustment
You might want to check the maintenance schedule to see all the things your car needs at the mileage and age it's at.
-air filter
-injector cleaner
-Valve adjustment
Check/flush/change fluids: tranny, clutch, brake, diff, coolant, and of course windshield washer fluid. Micron cabin filter. All depends on mileage. Look in the owners manual in the maint. section, it should all be there.
Thanks for the input, the problem is that the car didn't come with a manual.
The vehicle just hit 65,000 miles I don't know what the previous owner did or didn't do.
I am replacing the sparkplugs, sparkplug seals, and the valve cover gasket because the car came up with a check engine light. The light says it is cylinder misfires and there is oil in the spark plug housing.
Any other advice for this?? Thanks
You should have indicated why you wanted to do a tune up in the first place. This could have eliminated some of the "beating around bush".
Originally Posted by Kenpo_S2000,Jan 19 2006, 02:36 AM
Thanks xviper, do you think my VAFC II would have anything to do with it.
ps. For future reference, when you ask a question, you should state all the details right from the beginning, so that readers can better assess their response. You went from asking about a "tune up" it being a second hand car, to indicating that you have a CEL that points toward misfires and now to the fact that you have a VAFC. Leaving stuff like this out and sprinkling your subsequent posts with new information little by little makes diagnosis extremely hard and any responses given may not pertain as a result of the new info. Additional, any future questions will be suspect as you will have established a history of leaving vital information out.
mosmmc
Feb 20, 2009 07:38 PM
