Turbo Help!
Old Dec 30, 2004 | 05:54 PM
pinoydarv's Avatar
Default Turbo Help!
After doing some research. I have decided to go the turbo route. I am planning on getting the Inline Pro kit, AEM EMS and thicker head gasket. I was just planning on boosting 8 lbs ED and 12 lbs high boost. What kind of head gasket do you guys recommend. Also what clutch do you guys recommend. I would like a stock feel one. My goal is to have a fast S2000 not the fastest. Let me know guys.
Old Dec 31, 2004 | 04:33 AM
blues2k3's Avatar
since you are going with the Inline Pro kit you should ask them about what gasket works with their kit. I believe it's a Cometic headgasket but double check with them. As for the clutch you have a wide selection. The engagement will be a bit harsher than stock due to the material being used. Exedy, ACT, and Competition Clutch all have proven applications for forced induction S2000s. Good Luck
Old Dec 31, 2004 | 06:03 AM
ideugene's Avatar
I have a question on how much boost is safe using a thicker 3mm headgasket on an otherwise stock block?
Old Dec 31, 2004 | 06:10 AM
pinoydarv's Avatar
I have seen someone on the board boost 18lbs on a head gasket with stock internals. I'm not planning on boosting that much. Maybe 14lbs would be the most and 9 lbs everyday.
Old Dec 31, 2004 | 07:27 AM
pinoydarv's Avatar
I just got off the phone with Inline Pro. He said that the kit comes with their head gasket. I think I'm sold. Yippie!
Old Dec 31, 2004 | 01:45 PM
Venomous S's Avatar
Welcome to the 3mm gasket club!
KaNgArOo
Oct 23, 2008 09:45 AM
gdmlaz
Feb 23, 2008 12:32 AM
TheCarGuy2021
Sep 5, 2007 10:55 AM
bdowning
Jun 25, 2007 02:13 PM
timg
Nov 30, 2004 02:38 AM
