Turbo Install
Old Jul 9, 2004 | 07:16 PM
fperra's Avatar
It sure does sound like one or more of the pins in the Rocker assembly is/are missing.
Old Jul 9, 2004 | 08:06 PM
kane.s2k's Avatar
The oil filters themselves have a bypass valve built into them to prevent oil pressure from being too low. Not to mention that once the return line goes back into the engine, the pressure goes back to the same because the oil passages are still the same width --which is what counts. Plus the oil pressure light is a dummy switch...you would need almost no oil pressure for that to occur. I'm with the pins in the rockers for the vtec actuation.
Old Jul 11, 2004 | 05:17 AM
tms02's Avatar
They put in a brand new rocker arm assembly and the problem remained. IT is not the head.
Old Jul 14, 2004 | 07:43 AM
jeffxyan's Avatar
Any updates Todd? Also I did talk to John and he mentioned that the oil feed line wasn't at a direct 90 degree angle. Do you think it is this? I started this thread for some hope that your car will be done soon. Goodluck man.
Old Jul 14, 2004 | 12:47 PM
tms02's Avatar
I had them run a smaller diameter line , and bypass the relocation kit. No more Oil pressure problem. So now they are going to get the right size lines.
Now they have a problem with the rev limiter set on the AEM computer. It is kicking in at 7200 RPM.
I am having them put the stock ECU in to check that this is just a programming issue with the computer, and not a mechanical issue. If this works, then we are going back to the Dyno and complete the tuning and fix the rev limiter issue.
Todd
Japmuscle
May 31, 2013 08:47 AM
Rajdlos
Sep 4, 2010 02:18 PM
ChefJ
Aug 5, 2010 01:46 PM
ex-eclipse
Jul 18, 2006 02:47 AM
