Uninstalling a Remote Starter
Old Oct 22, 2008 | 11:19 AM
Jetpilot718's Avatar
Default Uninstalling a Remote Starter
Hey all,
I need some help, or at least a push in the right direction. I bought my S and it just came with a key. SO I bought another key. And a keyfob so I could use the alarm and power door locks.
I go to use it, and the only function that works is the trunk release. Doh.
I figured out why - the previous owner had a remote starter. Evidence was the left-over antenna, deleted neutral safety switch, and well, lack of the damn factory key-fob.
So my question - how do I reverse this? I wanna be able to use the OEM keyfob. Maybe if someone can link me to a remote start install guide or installation manual, I can work my way backwards from there.
Thanks in advance!!
-Steve
Old Oct 22, 2008 | 11:35 AM
devilchrist's Avatar
only wirecutting should have been starter motor wire and immobilizer data wire.
everything else should work properly.
and even then it should work as long as aftermarket is not alarmed.
on my 08 element my factory keyfob still works to control door lock/unlock
unless keyless entry is a option for 2001? i'm pretty sure it was factory standard?
Old Oct 22, 2008 | 03:13 PM
Got it to work, basically just undid a bunch of riggory that was under my dash and matched up the wires. Worked right away. I'm pretty surprised since I have no idea what I'm doing when it comes to that kinda stuff.
Thanks for the quick response tho!
Old Oct 23, 2008 | 10:41 AM
nice!.
Old Oct 23, 2008 | 11:31 AM
Stealth_SUX_'s Avatar
yep most likely when he did the alarm he cut out the factory unlock and lock wires from the factory keyless entry.. and used those to tape for aftermarket alarm
crank
Dec 23, 2012 12:59 AM
s20009k
Jan 12, 2010 04:57 AM
splatter85
Jun 17, 2009 08:08 PM
J's_Racer
May 24, 2007 07:51 AM
WhiteS2k
Dec 12, 2001 10:04 PM
