unknown wire under hood
Old May 29, 2015 | 04:17 PM
sanjay's Avatar
Default unknown wire under hood
Helping a friend look for an S2000. We came across this example today. There's this wire going to a coil?
I don't think mine has it
Any idea what it's for?
Not a good photo but it's the skinny green wire.
2005
Old May 29, 2015 | 05:20 PM
franky's Avatar
looks like the owner may fry one of the wires so he had to add a new wire. what did the seller say about it? and whats tat other big red wire for? as far as i know, there's no aftermarket electronic tat requires to run a wire to coil 3.
Old May 29, 2015 | 05:25 PM
sanjay's Avatar
the red wire is for the stereo
the green one is to a coil - but why does another wire need to be run?
Old May 29, 2015 | 05:26 PM
zeroptzero's Avatar
It might be an extra grounding wire, what is the box that is strapped to the air conditioner pipe ?, is the car running some form of earthing kit ? (extra grounds) . I'd ask the owner if the car runs without the wires installed just to be sure it is something significant and you can remove it.
Old May 29, 2015 | 06:11 PM
darcyw's Avatar
tell you what, that wasn't put there in Japan.
darcy
Old May 29, 2015 | 06:16 PM
AE_Racer's Avatar
As darcy said, definitely didnt come that way. Possibly a hacked in ground wire for that coil pack? Which would mean wiring issues... Stay away.
Old May 29, 2015 | 09:19 PM
NoMoreCivicsPlease's Avatar
The guy that owns it doesn't know?
Old May 30, 2015 | 04:12 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Looks like a tach signal wire for an aftermarket gauge (i would remove it and do it properly)
Or, an open circuit was found during a diagnosis, and someone ran a new wire instead of tracing down the break in the harness.
greatpratty
May 6, 2018 03:42 PM
robs2g1
Aug 26, 2011 06:23 PM
GDM S2K
Aug 6, 2010 12:37 PM
siadam
Jul 3, 2010 08:59 AM
GpWaP1 s2k
Feb 12, 2010 10:25 AM
