Update: Status of Blown AP1 Engine
Some one said that the bad oil jets are on some of the 2002 model S2000? I thought they were only on the 00 and 01 versions. If this is the case How do I know if I have bad oil squirters. I have a 2002 but I dont really want to tear my bottom end off if I dont have to.
Originally Posted by XclusiveAutosports,Sep 1 2006, 11:26 AM
If your new bottom end is not covered by Honda then I would look into building a new block (sleeved, forged rods and pistons) that can handle whatever FI abuse that you can throw at it. I know this isn't for everyone (especially if you are not FI before this happened), but I just figured I would throw it out there since the cost of a new short block from Honda must cost a pretty penny. You could always go with a used long block instead though. How much does a short block cost from Honda?
Here are some other helpful threads:
Oil Bolt Installation (In the FAQ)
Pictures of the different bolts.
Sticking w/ AP1 ECU. Alot of folks are running this setup and have been with no issues.
I was told that the oil jet bolts are not necessary since the recall was only done in Europe being due to the oil used over there...
