Upgrading Flywheel
Old May 21, 2005 | 12:57 AM
snake187's Avatar
Default Upgrading Flywheel
Hi everyong,
i have a Toda 3.5kg Flywheel i was plaining to install it but need to know is it best off upgrading the clutch? or can you just use the stock one?
Thanks in Advance people.
Andrew
Old May 21, 2005 | 06:00 AM
cdelena's Avatar
Certainly if you are going through all the trouble to put in the FW you will replace all the clutch components while in there. The consensus is an aftermarket PP (Mugen, ACT, etc.) for a bit more pressure but OEM FD. Be sure to do a complete job of cleaning the parts and proper lube on assembly.
Old May 21, 2005 | 06:25 AM
snake187's Avatar
Thanks for the advice mate.
Andrew
SickShift
Mar 27, 2010 11:19 AM
nMeOnE
Oct 31, 2007 08:01 AM
Boostedtaco
Jun 15, 2007 08:27 AM
waytooslow
May 8, 2007 06:39 AM
HondaGuy
Nov 14, 2000 09:16 AM
