Used MY04, Factory Oil Changed Too Early
Originally Posted by yyyiiikes,Feb 12 2006, 09:51 PM
I found the next circus act to be an over torqued drain plug.
I had a filter back off a little bit the first time I changed my oil. I haven't had one back off since. Also, make sure you check the oil level at least every other fillup. The owners manual says you should check it every fillup.
Lates
I used MityVac Fluid Evacuator to suck old oil out of the crankcase, I did not need to remove the oil drain plug. The oil filter can be removed and installed from the top without problem. I could do oil change without getting under the car. This MityVac Fluid Evacuator is used to do oil change for several cars, so that it is very cost effective.
When loosening the drain bolt, it is better to use a sudden snap of force rather than gentle and slow preasure. Gentle and slow can cause damage a lot easier.
Originally Posted by yyyiiikes,Feb 12 2006, 11:51 PM
The Ford clown that changed the oil last time really torqued on the filter. Before draining the oil (but after jacking up the car), I tried to turn the filter but could not so I resort to buying a filter wrench. After solving that problem, then I found the next circus act to be an over torqued drain plug. I struggled to turn it as gently and slowly as possible, but that was not how it was meant to be.
While the filter requires a lot of torque there are very few reports of a drain plug backing off, but some damage from over tightening. The spec on it is 29 lb/ft but frankly I never put that much on it.
I carefully applied more force thinking I would feel it slowly begin to turn... but it broke free in a sudden snap which resulted in my fist and wrench striking me in the face.
Lastly, I discovered that there was not a chrushable washer on the drain bolt...
Originally Posted by xviper,Feb 13 2006, 10:01 PM
If you can remove the oil filter by hand, then it was not installed properly or you are built like a gorilla.
Thanks for setting my expectations properly. This is different than other cars I have worked on where I was warned of the damage caused by over tightening. I would like to offer an apology to any Ford mechanics, clowns, or primates that may have been offended by my rash comments.
With respect to the oem filter I will give it a little more twist with the wrench. When installing, the OEM filter did have a softer feel after contact... meaning it seemed easier to twist than other cars/filters. Is it possible to measure torque on a filter???
But believe me, that Motorcraft filter was on there really, really, really tight.
I checked every where for the washer... especially looking and feeling to see if it was stuck on the drain pan. But I will take the Fumoto off next oil change and check again.
