vacuum tank location
so im finishing up doing a rebuild on my motor. started out needing a new timing chain and decided to do all new bearing and piston rings because she was burning almost 5 qts of oil in 3k miles. now everything is almost back together and i cant figure out where the vacuum tank mounts. the parts diagram looks like it mounts to the back side of the airbox but i cant figure out where. could someone possibly send me a photo so the stock location because all i can find online is where people are relocating them for aftermarket reasons.
It mounts to the back side of the metal cross member , the side facing the engine, should be a 10mm bolt hole around the middle of the cross member. That is lower than the air box.
Bob A (SD)
03-14-2004 12:07 PM
