vafc question
Old Apr 20, 2004 | 06:07 PM
VR WHAT's Avatar
Default vafc question
whats the last setting that says "initialize" - yes no. what's this function for?
thanx,
chris
Old Apr 20, 2004 | 07:04 PM
AZSnake's Avatar
[QUOTE]Originally posted by VR WHAT
Old Apr 20, 2004 | 07:28 PM
redsound's Avatar
[QUOTE]Originally posted by AZSnake
Old Apr 20, 2004 | 08:11 PM
Pdubb's Avatar
So if my friends Si got hit, and got it fixed but they reset the ECU (which i think put his A/F ratio back to the way it was) so his power is all off, no power up to 3k rpm, then the power feels very wrong after that. So i took it that his A/F got messed up when the ECU was reset, and the VAFC is messing it us. If he just resets his VAFC through the "Initialize" Will it just put his car back to the Stock settings?
Any help?
Thanks
Parker
Old Apr 20, 2004 | 09:21 PM
AusS2000's Avatar
No, it'll put the V-AFC back to IT'S stock setting, which probably won't be right for your Civic. That is, the MAP sensor type won't be 06 06, the number of cylinders may be wrong and the orientation of the throttle position may be incorrect.
Generally V-AFCs hold their setting regardless of power, but it shouldn't be hard to tell if it has been reset. Any changes in the A/F maps will be gone.
I would suggest you get a tuner to look at it.
Old Apr 22, 2004 | 07:37 AM
Pdubb's Avatar
Alright, thank you...
But as far as a normal Driver goes, theres nothing he can do to put it back to just Si stock settings? Just so the car runs a little better? Or tuned again?
Thanks again
Parker
Old Apr 22, 2004 | 09:20 AM
AZSnake's Avatar
Thanks again
Parker
Read the post above, if you initialize the v-afc it will set it to default. So you will have to change the sensor type (04,04 for an Si) the throttle position (arrow pointing up), and the engine type to 4 cyl. (which is default 6 cyl. I believe). If you have a manual look at that and it will help you out. Those should be all the settings you should have to switch, but its been a while since I had my Si. Then just wait till you go to the dyno to mess with vtec and your AFR.
bigmos2k
Apr 23, 2007 08:21 PM
2broke2drive
May 6, 2004 11:48 PM
VR WHAT
Mar 14, 2004 02:45 PM
BlueS2000Boy
Jan 18, 2004 02:35 PM
speeeding
Mar 4, 2002 12:38 PM
