Valve adjustment
Old Dec 20, 2013 | 07:06 PM
  #31
sillyboybmxer's Avatar
Originally Posted by andrew87890
Originally Posted by thebugsarebad' timestamp='1387577833' post='22932536
[quote name='andrew87890' timestamp='1387577121' post='22932516']
also inspected my retainers and all the head components, everything looked good!
Glad to hear it, i'm next up on the valve adjustment line.
only hard part is putting the vc back on such a pain in the ass
[/quote]
couldnt agree more.
I have been trying to get mine back on for over 2 hours! EVERYTIME I do this I try and remember what is the correct way to get that thing back on. I have no clue why sometimes it just falls on and the rest of the time it is a half inch away. I just dont get that damn thing
Old Dec 21, 2013 | 05:29 AM
  #32
zeroptzero's Avatar
Originally Posted by sillyboybmxer
Originally Posted by andrew87890' timestamp='1387581263' post='22932629
[quote name='thebugsarebad' timestamp='1387577833' post='22932536']
[/quote]
couldnt agree more.
[/quote]
remove the cam sensor bolt on the driver side of the cover and rotate the sensor downwards 90 degrees , leave the sensor inserted in the hole though. That will make a world of difference, then just put it back to position once the cover is in place. Torque the bolt on the sensor to 7 ft lbs.
You can wiggle it in with some effort without touching the sensor, but I'm always afraid of scratching my valvecover that way, so I just adjust the cam sensor. Remove the wire loom that runs along the firewall as well and tuck it underneath behind the head until the cover is in place then bring it back up, the wire loom gets in the way too.
Old Dec 21, 2013 | 08:22 AM
  #33
Thanks Joey. I actually found an old post of yours that was the issue. It is and always has been the spark plug tube seals. I could see they were all lined up and still I think "what the hell
I had never before actually tried to move them around a little bit through the top of the valve cover
I always just wiggled it around until it dropped on
Old Dec 21, 2013 | 08:49 AM
  #34
zeroptzero's Avatar
Oh yeah that can slow you down as well, particularly if they are brand new. Coaxing them over the sharp edge of the metal tubes with our fingers from above helps, a tiny bit of oil on their inside edge can help too.
Glad to hear you got it to work, it can be frustrating at times.
Old Dec 22, 2013 | 02:51 AM
  #35
wowwitsgau's Avatar
Originally Posted by wowwitsgau
Sorry to hijack the thread, but I had a question that might be helpful to anyone doing a valve adjustment as well
I did this for the first time last weekend, and noticed that there is some play in the adjustment screw assembly (you can push/pull it up and down and it will move accordingly, slightly). I did my adjustment with the screws pulled up, is this correct? I think squeezer mentioned that you are supposed to do it when they are pushed down, but would like a confirmation from others as well as a recommendation of whether or not it's that big of a deal such that I should redo the adjustment. Thanks!
Bump, anyone have an answer to this?
Old Dec 22, 2013 | 05:43 AM
  #36
zeroptzero's Avatar
Just stick the feeler gauge in the gap and see if it is loose or tight. If the cam lobes are in the proper position, and you have a gap, it makes sense that it can be moved by hand slightly. If you didn't have a gap it would be totally tight and that would not be good.
Once the proper sized feeler gauge goes into the gap, you use the drag on the gauge to see if it needs further adjustment. Don't press down on anything. Let the feeler gauge tell you all you need to know, hth.
Old Dec 23, 2013 | 09:54 PM
  #37
wowwitsgau's Avatar
Originally Posted by JFUSION
Originally Posted by wowwitsgau' timestamp='1387713103' post='22934102
[quote name='wowwitsgau' timestamp='1387333912' post='22927795']
[/quote]
I understand the concept completely. The issue I'm bringing up is that there is play in the adjustment screw, such that having the screw in the "lower" position or the "upper" position so to speak will yield a different gap measurement. For example, the .008 might fit perfectly with the adjustment screw in the lower position, but once you lift up the screw with your fingers it would feel loose. Hope that clarifies the question
Old Dec 23, 2013 | 10:05 PM
  #38
2003AP1's Avatar
I wonder if the misfire will come back, generally speaking I thought valve adjustments didnt cure actual "problems". just more of a fine tune.
Old Dec 24, 2013 | 10:00 AM
  #39
zeroptzero's Avatar
Originally Posted by JFUSION' timestamp='1387723418' post='22934185
[quote name='wowwitsgau' timestamp='1387713103' post='22934102']
[/quote]
[/quote]
Maybe I'm not understanding the question but I will try to provide more info if it helps ?.
Gravity causes the screw and locknut assembly to sit all the way down when the engine is shut down. Once you put the appropriate feeler gauge in the gap it should push the assembly all the way upwards, so there is no ability to move it upwards any further.
A properly adjusted valve clearance has the appropriate feeler gauge in the gap with a small amount of drag on it as you move it around within the gap. Pushing down on the screw and locknut assembly at that point would lock up the feeler gauge and it couldn't be moved or properly adjusted.
Old Dec 25, 2013 | 12:37 PM
  #40
andrew87890's Avatar
so i did my valve adjustment almost a week ago put about 100 miles on the car since cleared my CEl missfire(s) light. the light has not come back on since. so yeah im gonna say yes the adjustment can cure misfires. but also keep in mind my cel would only come on at a idle.
