valve lash adjustment
Old Nov 9, 2008 | 10:59 AM
jonnys2k01's Avatar
Default valve lash adjustment
should this be done cold or hot?.. what are the specs based on... temp wise
Old Nov 9, 2008 | 11:28 AM
negcamber's Avatar
Cold
https://www.s2ki.com/forums/index.php?showtopic=93197
https://www.s2ki.com/forums/index.php?showtopic=245555
Old Nov 9, 2008 | 12:51 PM
millertown15's Avatar
I set my valves when the engine is warm so to speak, when the cylinder head temperature is LESS than 100 deg. About room temp. Metal expands under intense heat, therefore your clearences will be a few thousanths different than if it were cold. .008" for the Intake side and .010" for the Exhaust side.
Old Nov 9, 2008 | 04:25 PM
jonnys2k01's Avatar
thats wat i just set it tooo.. i did it by the book.. to where .009 was rly snug or wouldnt go in... and so on for exhaust.... .011
but i still have alota valve train noise.. grrrr .. i originally did this to see if i could get rid of a slight tickint noise.. whihc i thought was a light valve tap... well now i got a hella lot of valve train noise... light the rockers are ticking... i wish i could let u guys listen to it.. but using a recorder still wouldnt do it justice... im just concerned... i would rather rebuild the head.. instead of the complete engine.. ya kno... but im not gonna rebuild head... if it doesnt need it.. bc the noise could be something entirely else...
its just mine boggeling rite now... btw ur red s2000 is ****ing sick!!!
Old Nov 9, 2008 | 06:00 PM
^ Appreciate that man. Looks much different now... Where are you located? If close I can maybe swing by.
Old Nov 9, 2008 | 08:57 PM
Wildncrazy's Avatar
Keep in mind these are solid lifters and will never be as quiet at hydraulic lifters.
Old Nov 9, 2008 | 09:09 PM
^ Very true
Old Nov 10, 2008 | 05:47 AM
snakeeater's Avatar
If you have a lot more noise after doing the lash adjustment, then you probably didn't get the clearances right. Did you have a written procedure to follow? Helm's manual? This isn't the easiest job to do for a beginning wrench turner.
kukudm
Jan 24, 2016 11:17 AM
jWESTFOO
Apr 21, 2014 11:51 AM
revto9k
Sep 26, 2011 11:47 AM
jonnys2k01
Dec 1, 2008 05:17 PM
