Continuous Scraping (?) Noise from Rear Wheel
Old Nov 23, 2012 | 01:30 PM
ultimaRicer's Avatar
Default Continuous Scraping (?) Noise from Rear Wheel
Hey everyone, I am having a problem with my new to me s2000 that I need some help diagnosing.
Over the past couple of days, my S has developed a rather loud scraping/moaning noise (not really a grinding noise) coming from the rear right wheel. It doesn't occur when I start driving, but usually develops after driving a mile or so. The sound doesn't go away when I step on the brakes and it doesn't seem to be dependent on wheel speed. When I slow down, it sounds about the same as when I'm at speed. It only goes away when I come to a complete stop, but starts back up again once I start moving again. There is also no noticeable vibration that accompanies the noise.
It is not the choppy/humming noise that is typically associated with a failing wheel bearing (again, it is a much louder noise), kinda sounds like an older school bus coming to a stop. I took the wheel off this afternoon and didn't see anything out of the ordinary (dust cover is not rubbing, brake pads still have meat, rotors look good). I couldn't get the caliper off because all of my tools are in my garage across town.
I'm leaning towards stuck/seized caliper or seized caliper pin, but I just want confirmation (or other ideas) before I dig in tomorrow. Hope I provided enough details, let me know if any more info can help.
Thanks in advance for your input
Old Nov 23, 2012 | 08:42 PM
BEASTMODE's Avatar
My wheel bearing that failed made more of a grinding moan that you described. Does it stop above a certain speed? Is it a constant noise or is it revolving noise?
Old Nov 23, 2012 | 08:55 PM
Chris_Lum's Avatar
did you check the inside brake pad also?
Old Nov 23, 2012 | 10:07 PM
apme123's Avatar
sounds like a wheel bearing issue caused by a lose axle nut
Old Nov 24, 2012 | 05:00 AM
flatrex's Avatar
Possible dust shield rubbing on the brake rotor
whomikedao
Jan 10, 2014 06:02 AM
chViETnk
Nov 26, 2013 04:34 AM
Spazzmeister
Apr 23, 2013 12:29 PM
purplemonkeydishwasher
Jun 1, 2011 03:53 AM
GavB
Mar 15, 2011 12:31 PM
