Vibration on accel
Old Oct 10, 2005 | 11:14 AM
FASTSIIK's Avatar
Default Vibration on accel
When accelerating I feel a relatively strong vibration, from maybe middle to rear of vehicle, at the same time this started my trans wont go into 5th gear. Its like there is something blocking it, it wont even grind with clutch in or out just wont go in. I know that the 5th gear thing is trans or shift linkages, but what is the vibration on accel? Trans, diff or drive shaft? It somewhat feels like the drive shaft is out of balance, is that common on s2's????? Help!! is this gonna cost me big bucks!!
Old Oct 10, 2005 | 11:20 AM
freq's Avatar
What year car? How many miles? Any mods done to the car that might affect these things?
The frequent posters in here are good but they aren't that good.
Old Oct 10, 2005 | 11:29 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Vibration.....Inner CV joints. Can be swapped side to side, no $ in parts.
5th gear...there's a tsb on non-engagement of 5th gear.
Old Oct 10, 2005 | 12:40 PM
FASTSIIK's Avatar
Its a 2001, i have no mods and about 8k miles ago i replaced the hubs and spindes for rear alignment issues. So i can just swap the axles from side to side and that will take care of the problem? and where can i get info on the tsb for 5th gear non engagment?
Old Oct 10, 2005 | 01:12 PM
Billman250's Avatar
Top Answer: 1
Not the axles, just the drive buckets....good info here:
https://www.s2ki.com/forums/index.php?showtopic=241367
Not sure where you'd find the TSB....It's here in s2ki somewhere
Old Oct 10, 2005 | 03:03 PM
twohoos's Avatar
TSBs are in the Library forum...but your 5th gear issue may be more than just moisture in the shifter housing (tsb 02-046). Could well be a burred synchro sleeve:
https://www.s2ki.com/forums/index.php?showtopic=325708
lacarion
Mar 7, 2016 05:47 PM
hyperkin
Jun 4, 2011 01:52 PM
houstonpv
Feb 3, 2009 06:28 PM
macs2000
Jan 19, 2006 08:16 PM
StudentDriver
Oct 25, 2000 05:07 AM
