voltage to cam sensor
Old Dec 28, 2023 | 05:51 AM
umair's Avatar
Default voltage to cam sensor
I am trying to diagnose a no start condition. How many volts are supposed to be at the cam sensors with the key on engine off? The car is getting voltage to the coils but no spark. also no injector pulse. Crank sensor is reading RPM.
Thanks
Old Dec 28, 2023 | 06:32 AM
spider2k's Avatar
Active Streak: 30 Days
https://s2000.club/OM/2000-08%20Honda%20S2000%20SM.pdf
Old Dec 28, 2023 | 06:44 AM
umair's Avatar
Thank you. So it should be 5 volts with key on engine off. It is not giving any voltage. It has an AEM ECU. I tried to plug a stock ECU but the immobilizer key was flashing so I was not able to test with stock computer. I tested continuity and everything checked out ok. My guess is that the computer is bad.
booost02
Mar 3, 2014 08:41 PM
blueducatikidd
Apr 21, 2011 06:11 PM
chikin tities
Nov 12, 2009 12:07 PM
BigpoppaHurtm
Jul 18, 2006 10:32 PM
s2000turbo
Jan 11, 2004 12:55 PM
