vtec solenoid
Old Jun 21, 2017 | 08:51 AM
AtlAP1's Avatar
Exclamation vtec solenoid
so im hopefully driving my new AP1 home tomorrow . it has a really rusty vtec solenoid. anyone have any tips on where i could order an completely oem one? or if there is a better designed aftermarket one please point me in that direction. thanks!
-Sean
Old Jun 21, 2017 | 06:48 PM
Janzen254's Avatar
Part number for replacement: 15810-PCX-A03
You could probably just sand and paint or polish. Another option would be a VTEC solenoid cover.
Old Jun 22, 2017 | 03:16 AM
Chuck S's Avatar
Leave it alone, the rust is cosmetic. If you insist just clean and paint it or cover it. No aftermarket
Old Jun 22, 2017 | 08:00 AM
AtlAP1's Avatar
o ok! cool! really? i probably just go the clean and paint route. ill post some pics of the rust. that makes me feel a lot better tho! thank you
Old Jun 22, 2017 | 08:58 AM
HarryD's Avatar
Many/most of them are rusted -- just the way the materials on that part are.
As a new owner, you should religiously keep an eye on oil levels (every gas-fill-up) -- there's a proper way to read the dipstick and a false way to read the dipstick. I'd also do a baseline fluids flush after you get home, as well as swap out the plugs (and make sure they're properly torqued -- 24ft-lb), as well as inspect the valve retainers and do a valve adjustment.
After that, the car is bulletproof, as long as you keep an eye on the oil levels.
Old Jun 22, 2017 | 09:24 AM
cosmomiller's Avatar
Top Answer: 1
Take some time and search through the forums. You will discover a lot of great info on new ownership. There are some things that will surprise you but it all leads to building a knowledge base about this car and how really great the design and engineering are of the beast.
Rust is what you get when the car is not from the west coast/southwest desert area.
Old Jun 26, 2017 | 04:01 AM
LaosguyAP1's Avatar
check if there is any oil leaks coming from there, I just replaced the top and bottom gaskets on mine. Ballade sports sells both for $45 https://www.balladesports.com/produc...c-gasket-combo
Old Jun 26, 2017 | 05:09 AM
Chuck S's Avatar
Or $26 + free shipping from an Ebay source!
-- Chuck
MikeArt
Mar 10, 2014 07:15 AM
s2000zr
Nov 27, 2010 06:27 PM
dangators05
Apr 14, 2006 10:29 AM
JerseyGirl
Sep 11, 2003 06:50 AM
