Vtec Solenoid Problem
Old Mar 12, 2008 | 06:27 AM
K4RL's Avatar
Default Vtec Solenoid Problem
Hi Guys help needed,
My CEL keeps coming on with the Error Code 1259, after doing some searching I believe it has something to do with my Vtec Solenoid.
After doing some searches, I have found this suggestion
Remove the VTEC solenoid from the block (three bolts), remove the gasket (15825-PCX-015, FILTER ASSY., SPOOL VALVE), clean it or replace it. I have opted for the latter and ordered a new one. .
I have noticed that there has been some oil leakage (not a lot) around the VTec Solenoid housing where it connects to the Block could that be a broken gasket?
Is there anything else I should try?
Many thanks
Old Mar 12, 2008 | 09:56 AM
Apex_AP1's Avatar
Many thanks
Im sure u will be fine after getting a new one. They sometimes go bad anyways.
Old Mar 12, 2008 | 01:30 PM
NVMY4N's Avatar
I removed mine cleaned it, iit wasn't the problem but it wasn't hard to do either.
you should have it scanned while driving to see if it is working properly
Old Mar 12, 2008 | 02:08 PM
K4RL's Avatar
Hi thanks for the reply, what do you mean Scanned ?
thanks
Old Mar 12, 2008 | 04:01 PM
PrecisionS2K's Avatar
thanks
he means use a scan tool. it lets you check engine codes and look at sensor data, among other things. really good for diagnosing electrical problems and such.
Old Mar 12, 2008 | 06:50 PM
Slows2k's Avatar
Check oil level 1st.
Old Mar 12, 2008 | 11:16 PM
K4RL's Avatar
Thanks Guys
slows2k First think i did mate.
i have a CEL Code Reader hence the P1259 code which i pulled. So will change the filter / Gasket and run it, and see if an error pops up.
toniotran
Jan 18, 2020 01:23 PM
Mr. Slowly
Jun 5, 2016 06:44 PM
Shaney
Jan 7, 2015 08:30 PM
Tyraid2K
Jun 21, 2010 09:38 AM
tnolo585
Jul 21, 2009 02:04 PM
