Vtech,Just Checking???
Originally posted by RT
Interesting Josh, didn't think of it that way (although it make good sense) but I could swear I've seen my MAP fully saturated at partial throttle (SC'd) and still saw the delay ........ I'll pay close attention to it on the way home and report my findings.
Another illustration of how ambient air pressure affects power delivery: now that I have a V-AFC I set on to 5.8k, off 5.6k (the VAFC removes the variable engagement point due to ambient pressure). When VTEC engages when there's a low pressure system in the area my powerband is significantly smoother than during high pressure times without changing the MAP correction.
be mindful of the dreaded ignition timing map mismatch, don't linger in the DeadZone for too long
I did do what u said however and set my unmatch to -5% to fix the noises at steady state in the "dead zone"
I'd bet that the ECU has a hardcoded MAP value for VTEC engagement.
MAP changes value based on rpm, TPS and ambient pressure.
chemistry 101:
V=nRT/P
V=volume
n=mole count
R=gas constant
T=temp
P=pressure
Lower pressure also means lower density (higher volume), which means less combustion. If the ECU didn't recognize that then it could get into some serious trouble when the weather changes
Based on the basic gas law, you'll have worst performance when it's hot and low pressure (HT_LP), like in a Floridian summer storm, and best performance when it's cold and high pressure (LT_HP), like the CA central valley in winter. This also means that power deltas between cam lobes change, meaning a smoother powerband in HT_LP and more noticeable VTEC in LT_HP.
c'mon Mr. freebody diagram, you should know this stuff!!
chemistry 101:
V=nRT/P
V=volume
n=mole count
R=gas constant
T=temp
P=pressure
Based on the basic gas law, you'll have worst performance when it's hot and low pressure (HT_LP), like in a Floridian summer storm, and best performance when it's cold and high pressure (LT_HP), like the CA central valley in winter. This also means that power deltas between cam lobes change, meaning a smoother powerband in HT_LP and more noticeable VTEC in LT_HP.c'mon Mr. freebody diagram, you should know this stuff!!
....does the ECU monitors the ambient atmospheric pressure ...
Originally posted by The Unabageler
It's more a matter of MAP than of throttle position. At WOT at high elevations VTEC will also be delayed, and I've noticed VETC engagement changes when the weather changes.
