washer sizes
Old Jan 11, 2012 | 01:58 PM
trustafox's Avatar
Default washer sizes
what are the washer sizes for the
sump plug washer
gearbox drain plug
gearbox filler plug
diff drain plug
diff drain filler plug
I think I've got all of them?
Does it matter if any are copper or aluminium?
Old Jan 11, 2012 | 02:34 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
engine drain plug washer 14mm
gearbox drain plug 14mm
gearbox filler plug 20mm
diff drain plug 18mm
diff drain filler plug 18mm, COPPER from factory. all others are alum.
Old Jan 12, 2012 | 04:02 AM
trustafox's Avatar
Is there any reason they chose copper for just that one? I assume swapping to alum would be fine?
Old Jan 12, 2012 | 05:15 AM
Billman250's Avatar
Top Answer: 1
im sure alum is fine.
Old Jan 12, 2012 | 01:18 PM
trustafox's Avatar
I'm assuming right these are the internal diameter?
Old Jan 12, 2012 | 01:41 PM
dwight's Avatar
You assume correctly, and for reference the OD of the 14mm aluminum one is about 24mm.
gospeedgo1
Apr 27, 2009 01:42 PM
Su2uKa
Sep 24, 2007 10:41 AM
rikhemi
Nov 21, 2005 12:44 PM
JSR_AP2
Dec 4, 2004 03:46 PM
REVS29K
Mar 12, 2001 08:18 AM
