Water pump question
Old Oct 29, 2008 | 12:25 PM
JS2k.com's Avatar
Sponsor
Default Water pump question
Update: It isn't the water pump that was making the noise, although it does sound exactly like it's spraying water out of a small nozzle or something. It was the tensioner pulley's bearing that is going out.
The water pump is making a noise like it is spraying water, but I'm not losing coolant.
At 70k miles, should I need to replace the belt since it may have been stretched out due to the wobbling?
How hard is it to swap the whole water pump? I couldn't find a DIY. I've changed a starter and removed the alternator while doing it, with the help of a friend.
Thanks!
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Oct 29, 2008 | 02:20 PM
ahrmike's Avatar
if its making noises sounds more like the bearing and the blades behind the water pump are fkkd as well.
just do it man! dont wanna blow your (overheated) engine cuz you didnt wanna buy a couple hundred dollar part.
just my 2cents.
Old Oct 30, 2008 | 06:27 AM
snakeeater's Avatar
You might try removing the belt and then grab all the pulleys one at a time. Give each a good groping to check for movement. If any one of them allows movement other than spinning on its axis, then the bearings on that shaft are loose. Any significant axial or radial slop in the bearings require replacement. It's usually easier to replace the entire part than to replace the bearings and seals. But if you have a good bearing supply store nearby, it is definitely cheaper to rebuild it yourself. Hope you get it figured out.
Old Oct 30, 2008 | 08:15 AM
loftust's Avatar
My previous car made a similar noise to the one you're describing before it catastrophically destroyed itself doing 80 on the motorway, the head gasket then went 'ka-boom!'.
I hadn't lost any coolant before that either.
I agree with the above, but would replace the waterpump to be on the safe side.
Old Oct 30, 2008 | 09:46 AM
JS2k.com's Avatar
Sponsor
Thanks guys. I will get that water pump replaced. Anyone know how easy or difficult it is to replace? I've removed the alternator to replace a starter with the help of a friend.
__________________
_________
Old Jul 14, 2009 | 09:07 AM
2001_s2000's Avatar
Can anyone here help with my issue. I have a sound at idle and not sure.
https://www.s2ki.com/forums/index.php?act=S...0#entry16645865
Old Jul 14, 2009 | 11:50 AM
WarrenW's Avatar
While we're on the subject of water pumps - anyone know if the impeller in the S's waterpump is plastic or metal?
Old Jul 23, 2009 | 09:22 AM
2001_s2000's Avatar
Metal
Old Aug 13, 2009 | 08:50 AM
JS2k.com's Avatar
Sponsor
Figured it out. It was the tensioner pulley's bearing that is going out.
__________________
_________
rob-2
Feb 16, 2019 12:13 PM
ATL_S2K
Oct 21, 2009 07:41 AM
btstone84
Jun 21, 2008 08:26 PM
