weak clutch (2000 S2k)
Old May 30, 2001 | 07:13 AM
chillios's Avatar
I have been having clutch slip problems with my 2000 s2k.
Anyone else been having problems?
As an asside, when the 2nd gear grind TSB is repaired, will they replace the clutch as well? (it doesn't appear that way in the TSB.)
Old May 30, 2001 | 08:23 AM
cmnsnse's Avatar
They would rather do it at the same time
I had mine done at 30,000 mi
I would suggest an aftermarket pressure plate because they are so small in diameter and surface area, also a different clutch disc.
I went stock but had to replace the flywheel/pressure plate also, due to wear.
wankun
Oct 26, 2016 01:18 PM
dyhppy
Sep 14, 2013 10:42 PM
ywouldi
Jul 3, 2011 10:22 AM
Ron
Jun 2, 2007 01:23 PM
Naka
Dec 12, 2004 07:06 PM
