weird electrical problem
hi guy!
i need some help!!
i have electrical issue with my car..my car have many component stopped working..
battery is relocated to trunk and engine bay tucked .the
cruise control button,rear defrost button, heater blower fan,
fan radiator ,and also wiper intermittent mode are not
working... i tryed to jump the ground on fan radiator direct to - ,didnt work more,but when i jumped 12 direct to battery ,the fan started..
on fusebox under-dash "auto stop wiper" i read 3V... i dont know if it normal?
i need some help!!
hi guy!
i need some help!!
i need some help!!
Ok "cruise control button,rear defrost button, heater blower fan, fan radiator ,and also wiper intermittent mode are not working." So all of these have the dash harness in common. I would have to look, but I think they are all on one harness of the two under the dash. Radiator fan, that is completely on a completely different circuit, mostly under the hood. There is also one connection to the ECU. So this is going to have been touched by the tuck job. The wiper intermittent mode is controlled by the dash cluster.
Really I would advise you hired someone to trace your issues. I am sure there is a break somewhere in the harness.
i dont think theres a cut in the harness..
i know they are almost all on the same ground which is fender ground (ground 301)
also,when i did the tuck,only 5 wire has ben cut(eps wire),and has ben soldered..
i used #2 wire for relocation.
musicforthedeaf
Jul 1, 2016 12:17 PM
richierich
Nov 6, 2015 03:09 PM
nomadicS2k
Aug 20, 2011 08:10 AM
