Weird engine knocking.
Old Sep 26, 2013 | 12:40 PM
2valve's Avatar
Default Weird engine knocking.
On cold starts, I'm hearing what sounds like bottom end noise. I've watched videos of other S2K owners with knocking and this doesn't sound the same. I'm pretty sure it's not the timing chain tensioner, doesn't sound anything like the card in the spokes sound. Other people with rod knock say theirs only does it when the engine warms up. I was hoping someone could enlighten me or maybe someone has experienced a similar noise on cold starts. Sorry about the video, I was in a rush to take it and forgot to disconnect the air pump, but you can hear the noise very well at 6 seconds in before the air pump kicks on. The clump sound just after the knocking starts is me dropping the clutch, just fyi. If its too hard to hear I'll try it again after I get home from work. Thanks in advance!
http://s139.photobucket.com/user/Ora...60338.mp4.html
Old Sep 27, 2013 | 07:36 AM
03 9g's Avatar
That does noit sound good ...Id stop driving your car asap and get it to a shop for inspection of the issue ...my best to you getting it fixed soon.
Old Sep 28, 2013 | 06:19 AM
INDYMAC's Avatar
I don't hear anything unusual. But i could be going deaf. Sorry!
Old Oct 1, 2013 | 05:36 AM
2valve's Avatar
Well I did a compression check and all 4 cylinders were the same, well over 250psi. Just installed an oil pressure gauge and oil pressure is great. Cold idle is just below 90psi, warm idle is around 20. Peaks at almost 100 at WOT, so I know its not starving for oil. I've heard TCT's going bad and it doesn't sound like that, but that's my next step, that and a valve adjustment.
Old Oct 1, 2013 | 05:53 AM
s2000maniac's Avatar
It's normal, it's the cold piston slap. As long as it doesn't make it when the engine is warm.
Old Oct 1, 2013 | 10:32 AM
2valve's Avatar
No it quiets down and sounds normal when it gets to operating temp. That's something I'm definitely not used to, why does it do that?
Old Oct 1, 2013 | 10:59 AM
It's just the nature of the engine
Old Oct 1, 2013 | 12:44 PM
2valve's Avatar
I suppose it is. Just read up on some other threads (https://www.s2ki.com/s2000/topic/785283-piston-slap/)and it seems others have had this exact "issue." I might experiment with different oils to see if that helps. But from what I've read there isn't much you can do about it, as long as it doesn't hurt the engine I don't care what noise it makes.
titus69
Dec 7, 2014 03:42 AM
Floppy
Apr 29, 2010 08:48 AM
kill
Mar 4, 2007 08:04 PM
spyhunter
Aug 2, 2005 05:21 PM
MDS2K
Mar 5, 2001 09:01 PM
