What does this mean?
Old Oct 20, 2008 | 05:30 PM
dtmcnamara's Avatar
Default What does this mean?
Ok so I put my car into first yesterday. Slowly let off the clutch like normal and gave it a little gas but nothing....I completely let off of the clutch with it in first and nothing. gave it gas, and it only reved. Then i tried to pull it out of first with the clutch in, thinking hell maybe it wasnt. but it would not let me pull it out until i had the clutch in.
I put the pedal back in pull the shifter out and then back into 1st and it worked....
first time this has ever happened. Think I should start to look around for transmissions?
Old Oct 20, 2008 | 05:45 PM
learning03's Avatar
My AP1 does the same thing, 20,000 miles later tranny still does it and not a hint of transmission failure. You should be fine, how many miles do you have?
Old Oct 20, 2008 | 05:50 PM
2poor2mod's Avatar
check the fluid level in the master cylinder, yours may be extremely low letting air into the system
Old Oct 20, 2008 | 05:53 PM
dtmcnamara's Avatar
thats what I was thinking but all fluid levels are fine....also my tranny has 58K. I think I may just get another one. I am hitting a notch in 2nd, 3rd, 4th, and 6th right now. with it getting cold quick I could pull the tranny and get something else and not have to rush everything
Old Oct 20, 2008 | 05:54 PM
2poor2mod's Avatar
did you try bleeding the clutch?
Old Oct 20, 2008 | 06:17 PM
dtmcnamara's Avatar
i have actually. but like I said it was the only day it has ever hapened. also I do not see how any air could get into the lines. I use a bleeder system from Motive Products...
http://store.motiveproducts.com/shared/Sto...ount2=671912789
Revs 2 9K
May 1, 2012 03:38 PM
IRev2NineK
May 26, 2008 06:00 PM
c blues 02s2
Jul 24, 2007 08:00 PM
Goldtrom
Jan 27, 2006 09:57 PM
