Is this what I need?
Old Sep 17, 2005 | 10:05 PM
folex187's Avatar
Default Is this what I need?
http://racingdimension.com/index.asp?PageA...PROD&ProdID=685
"RC Fuel Injector Plugs - A Set of 4
RC Fuel Injector Plugs/Clips"
Are these the clips I need to wire in RC injectors? Also, I have heard you need to use some kind of spacers also? Where would I find these?
Old Sep 18, 2005 | 01:48 PM
folex187's Avatar
Bump for the day
Old Sep 18, 2005 | 06:50 PM
Sideways's Avatar
I found their spacers too large. I ended up using some washers to space the fuel rail correctly. Simple.
Old Sep 18, 2005 | 07:04 PM
AusS2000's Avatar
The provided link is just the electrical connectors. I used 5 x 5mm spacers for the rail and supports, and some O-rings on the base of the injectors.
Old Sep 18, 2005 | 07:10 PM
folex187's Avatar
I need the electrical connectors too right? Aus- where did you get the spacers? Are they just like washers?
Old Sep 18, 2005 | 07:15 PM
AusS2000's Avatar
Washers will do. Mine are just bits of Al tube cut to 5mm.
Old Sep 18, 2005 | 07:19 PM
folex187's Avatar
Good idea!
Old Sep 19, 2005 | 06:52 AM
Ztec's Avatar
I had a problem with the supplied spacers from RC but after I call them realized the spacers for the fuel rail go on the bottom of the OEM standoff's - the instructions were confusing at best.
Suzuka_Joe
Nov 6, 2018 09:54 AM
ChefJ
Jan 15, 2009 04:57 AM
chairmnofthboard
Dec 6, 2007 08:22 AM
gotswap
May 19, 2006 09:27 PM
rick bailey
Nov 9, 2005 01:21 PM
