What is this noise from? Pulley? CCT?
Old 05-23-2017, 07:06 PM
treimche's Avatar
Default What is this noise from? Pulley? CCT?
2005 S2000 now with over 146,000 miles and it makes this grinding/screech noise once in a while on cold startup. It only happens for a half second or so and goes away. I can't pinpoint the exact scenario when it happens though. From my searching, it doesn't seem to be the noise a typical failing cam chain tensioner makes. Maybe its one of the pulleys? I did pop the belt off the other day and the tensioner pulley seemed a bit wobbly and rough, or maybe it was the idler, I can check again but both felt a bit rough.
Just stumbled across something else that said this noise could even be the starter?
File Type: mov
Old 05-23-2017, 11:33 PM
Car Analogy's Avatar
Received 1,321 Likes on 999 Posts
Search for cold start noise. You will find no end to threads about it. Its the starter.
All S do it when its cold out. There is no reliable fix. Its harmless, and merely annoying.
Everyone just learns to live with it.
Old 05-24-2017, 04:29 AM
GSteg's Avatar
It's apparent in many older Honda 4cyl as the starter starts to show their age. Thankfully mine doesn't do that (yet), but it's not as cold here as it is in ND.
Old 05-24-2017, 05:02 AM
treimche's Avatar
Thank you for the help. I'm guessing that replacing the starter would eliminate the noise.
Old 05-24-2017, 06:21 AM
windhund116's Avatar
Received 1,441 Likes on 966 Posts
May wish to look at this video on starter Bendix unit. How it works and how to free it up. Even though, not Honda car starter... principle is the same.
Old 05-24-2017, 07:57 PM
kschoenefeld's Avatar
Default Not Just S2K
My Type-S RSX does it too. Consensus is not to worry about it.
Trailerparktrev
08-03-2012 11:04 PM
BodyCest
12-06-2011 06:02 AM
Bandit_287
07-23-2009 09:46 AM
Competitor9
02-22-2009 04:54 PM
jwkim
02-06-2005 08:56 PM
Quick Reply: What is this noise from? Pulley? CCT?
