What is this part?
Old Nov 15, 2009 | 11:48 AM
spectacle's Avatar
Default What is this part?
Directly under the TCT, has a rubber cover over it - yellow wire with red stripe. Looks like its got something to do with the vtec solenoid.
Thanks.
Old Nov 16, 2009 | 04:10 AM
spectacle's Avatar
Come on someone knows. Its a wire terminal connected to a plug directly connected to the block.
Old Nov 16, 2009 | 04:24 AM
Slows2k's Avatar
Oil pressure switch for the idiot light on the cluster.
Old Nov 16, 2009 | 04:30 AM
AusS2000's Avatar
Under the TCT is the oil pressure switch.
Old Nov 16, 2009 | 04:33 AM
JustinC's Avatar
Old Nov 16, 2009 | 06:29 AM
spectacle's Avatar
If I lose that connection will that trigger the oil pressue light to come on? I assume its some sort of short type system.
Old Nov 16, 2009 | 10:23 AM
Kyushin's Avatar
Banned
No, mine was disconnected when I installed an aftermarked oilpressure gauge and I dont have any CEL with it.
Old Nov 16, 2009 | 06:55 PM
Slows2k's Avatar
That oil pressure switch is not connected to the PCM. If you ground that wire the low oil light will come on.
S2K-F8
Nov 26, 2014 06:49 PM
stezie
Dec 15, 2011 07:16 PM
Bikey
Apr 13, 2010 07:58 PM
ChefJ
Jan 7, 2008 06:58 PM
Bass
Jul 17, 2004 08:55 PM
