What type of torque wrench do you have? How necessary is it?
Gear Heads
j/k
Lots of good info.
I can't do this off the top of my head so, a little sumpin, sumpin about Torque Wrenches
Up Tight With Torque Wrenches
corner
j/k
Lots of good info.
corner
Geez Bill, you're a smart guy! It was an honor to have had lunch with ya.
Good examples of what Bill just said:
-The crank pulley nut. Not surprising that it has been noted that it can take up to 500 ft/lbs to remove when it was put on with only 181.
-The spark plug cover Allen Bolts. You have to "snap" these loose right off the bat or you'll round off the heads.
-Same with the coil pack hold down bolts.
In fact, many of the nuts and bolts on our car is like this, so take care.
Okay, I have one of the cheap clicker style torque wrenches. So far, I've only used it for lug nuts, but I also planned to use it on the various drain/fill bolts. If I'm setting it to approximately 30 lb-ft for the drain/fill bolts, do I care if I'm off 10 or 15% in either direction? Can anyone better characterize the amount of inaccuracy to expect in this type of torque wrench? Do they tend to read high vs. low, etc?
Jeff
Jeff
Slalom, good write-up.
The oil drain bolt torque specs are, I assume, always calculated dry. So either 1) how the hell do you get every drop of oil off the threads or 2) what's the conversion from dry ft-lb to oily ft-lb?
Rusler Firbrand
Feb 14, 2006 07:12 PM
