whats the difference between vtec and i-vtec?
Old Aug 1, 2003 | 12:31 PM
YOD88's Avatar
Default whats the difference between vtec and i-vtec?
i heard that 2004 model of the s2000 might have i-vtec, i've searched on the difference between vtec and i-vtec but there wasn't anything relating to it, so i was wonder wats the difference.
Old Aug 1, 2003 | 12:43 PM
Wesmaster's Avatar
I-VTEC is infinitely variable, instead of having a hi and low setting it changes dynamically throughout the RPM range.
Old Aug 1, 2003 | 01:03 PM
Gernby's Avatar
Former Sponsor
I-VTEC still just has 2 cam profiles for lift and duration just like VTEC. The difference is that valve timing is continuously variable, so the cams can be advanced or retarded by the ECU.
Old Aug 1, 2003 | 01:06 PM
Wesmaster's Avatar
My bad.
Explained here:
http://www.canadiandriver.com/articles/jk/...11205.htm&e=912
Old Aug 1, 2003 | 01:20 PM
Triple-H's Avatar
And technology aside, some would say the transition is felt more when jumping to VTEC than in a car jumping into i-VTEC, the variable valve timing across the rev range smoothes out the transition.
Old Aug 1, 2003 | 01:24 PM
vapors2k's Avatar
advantages: torque curve starts earlier and remains flat, more potential in peak power output.
disadvantages: more circulating mass...some speculate a higher rate of failure to traditional VTEC in endurance racing.
Old Aug 2, 2003 | 10:06 AM
jsrsx's Avatar
I never thought about the additional weight of the valve timing gear that's under ecu control, but other companies such as BMW has been running near-indentical technology in racing for years w/ success (VANOS). Most other brands have some sort of VTC...Honda's more unique in that it has variable cam profiles.
Old Aug 2, 2003 | 10:12 AM
Gernby's Avatar
Former Sponsor
Honda doesn't have variable cam profiles. There are 3 discrete profiles for intake, and 3 discrete profiles for exhaust. Two of the profiles are very similar (Primary & Secondary non-VTEC) and the other is the aggressive VTEC profile.
arprice
Jun 2, 2007 03:48 PM
94509397
Apr 27, 2005 03:49 PM
Killashahmafia
Dec 27, 2004 10:27 AM
Hyper-X
Sep 11, 2004 10:33 AM
MeTh222
Aug 22, 2002 02:51 PM
