Whats wrong?
Originally Posted by davidvonyork,Nov 4 2006, 07:58 AM
Currently my foot has to be pressed in a bit to disengage the clutch, and not far at all to engage it again? If my clutch was going i think the clutch pedal would be all the way out almost and not engaging right?
If your clutch was going then you would be slipping and getting the nasty clutch stank when it happens etc. You say it holds fine till 9k rpm so I wouldnt be so concerned about that just yet. A bottle of DOT 3 is a couple of bucks and the bleed/ flush is free if you DIY or whatever labor your shop charges. Its the starting point since you had empty reservoir. A clutch job can cost mucho $ for parts and labor so that can wait until you confirm any problems with the clutch. Let us know the outcome!
CHad
for Good info, im currently having the same issue
