wheel alignment suggestions...
Old Jan 27, 2014 | 01:00 PM
S2K Sideways's Avatar
Default wheel alignment suggestions...
I've been browsing through old posts about alignment specs but I can't seem to figure out what to do…
I am running RPF1's staggered … 17x8 front and 17x9 rears … Should i just go based off the OEM suggested and tweak from there? I'd like a little more neg camber …
Old Jan 27, 2014 | 01:13 PM
ZDan's Avatar
For long tire life and good handling characteristics, I recommmend:
zero front toe
-1 degree front camber
0.2 to 0.3 degrees total rear toe
-2 degrees rear camber
Old Jan 28, 2014 | 04:54 AM
iamxpl's Avatar
^^ very good place to start. its close to UK spec, i had my caster maxed out. not sure how that will affect tire wear for street driving.
Old Jan 28, 2014 | 10:55 PM
ZDan's Avatar
Critical problem with the "UK spec" is that it calls for an ABSURD amount of rear toe at .67 degrees total. Awful for handling, disaster for tire wear!
I didn't mention caster because it can be kind of subjective. Many just go with the max they can get, but personally I prefer minimal caster, in the 5-5.5 degree range. To me, too much caster just adds artificial weight to the steering and can mask feel a bit.
Old Jan 29, 2014 | 03:45 AM
iamxpl's Avatar
i guess im biased due to autocross. i only ran 1/16th total toe in rear.
08s2000CRbackinblack
Jul 21, 2017 01:53 PM
RoninS2k
Nov 24, 2012 08:32 PM
02S2Grand
Jun 7, 2008 05:12 PM
Scot
Sep 2, 2004 07:17 PM
Squeezer
Mar 28, 2003 09:32 AM
