Wheep gap between rotor and wheel
Old Oct 22, 2004 | 01:54 PM
YeLLoWs2knVA's Avatar
Default Wheep gap between rotor and wheel
I just put my stock rims back on and the rear driver's side has a gap. The gap is between the actual wheel and the little round part on the rotor where u mount the wheel. When I drive and let the steering wheel go to see if it goes shake, the wheel shakes back and forth maybe 1/4 of an inch back and forth.
When i took the Volk rim off that I had on, there was no gap. However, the rim was kinda stuck to the rotor i guess due to rust and i used WD 40 to take it out.
Any suggestions? I am fearing this might hinder my steering and handling.
Old Oct 22, 2004 | 03:48 PM
cdelena's Avatar
You probably have the front and rear wheels mounted in the wrong position.
Old Oct 22, 2004 | 05:32 PM
davepk's Avatar
Take the wheel off and check for a hub centric ring stuck on the hub. Chances are you also have another hub centric ring stuck inside the wheel as well. When doubled up on a single wheel the two rings prevent the wheel from sitting flush against the hub.
Your wheel will eventually fall off if this is the case!
What do you mean? I didnt know there were different positions you can mount the wheel into.
If you mean I got the front and back switched, it doesn't take genius to figure which one goes front and whihc goes back.
Old Oct 22, 2004 | 05:40 PM
koala's Avatar
I think you left your hub centric ring on there from the Volk wheel. If you take the stock wheel back off, you'll probably see a little plastic ring in there that shouldn't be used with the stock wheels.
Hope this helps!
Old Oct 22, 2004 | 05:43 PM
davepk's Avatar
I was thinking you reinstalled the Volk wheels.
With the stock wheels there should not be a hub centric ring installed.
Old Oct 22, 2004 | 05:45 PM
davepk's Avatar
BTW, my Volk CE28N wheels came with Aluminium rings.
Old Oct 22, 2004 | 06:10 PM
Do they just pull off, or do they twist?
Old Oct 22, 2004 | 06:37 PM
koala's Avatar
Ah, good to know. I've seen them come only with plastic ones myself
FUSIONX8887
Jun 10, 2011 12:26 PM
JohnnyRingo
Nov 15, 2005 09:36 AM
simonprelude
Jun 1, 2005 01:13 PM
