When to Adjust Valve?
Old Mar 25, 2009 | 02:33 PM
  #21
xeuxx's Avatar
Originally Posted by jimbosr1,Mar 25 2009, 01:16 PM
just did mine at the dealer today..it was $134.
Is that 2 hours labor at your dealer then?
Old Mar 25, 2009 | 02:53 PM
  #22
pistolpete17's Avatar
Anyone have specs on AP2 (MY07)?
Old Mar 25, 2009 | 03:21 PM
  #23
Jacksparrow's Avatar
http://www.youtube.com/watch?v=YguimOCYCqY
Old Mar 25, 2009 | 04:55 PM
  #24
jimbosr1's Avatar
labor was $104.the rest was the seal kit..
Old Mar 26, 2009 | 04:23 AM
  #25
TKim103's Avatar
got mine done last night
a few intake and exhaust valves were out of spec (i'm at 41K miles now)
It definitely idles smoother in conjunction with a new map sensor and air filter. It doesn't bog anymore whenever I release the throttle completely (slight hop), same with acceleration. The car definitely pulls a lot smoother.
Old Mar 26, 2009 | 09:23 AM
  #26
Good idea to use a new valve cover gasket?
Old Mar 26, 2009 | 10:07 AM
  #27
TKim103's Avatar
you won't need a new one unless your head is leaking
Old Mar 26, 2009 | 12:02 PM
  #28
jeffbrig's Avatar
pete, you can reuse the gasket, but I would only do it once or twice without getting a new one. The kit is ~$17 at hardtopguy, so that's cheap enough.
Old Mar 27, 2009 | 09:54 AM
  #29
slimjim43's Avatar
Originally Posted by truancy143,Mar 25 2009, 01:54 AM
idles smoother. pulls more consistently throughout the band. That's the butt dyno talking perhaps but I trust it.
Car is at 60K and never had valve adjusted. Currently, car idles smooth and runs pretty good. Should I still get adjusted?
Old Mar 27, 2009 | 11:35 AM
  #30
jeffbrig's Avatar
If the idle is smooth and the valvetrain is quiet, no reason to go looking for trouble. You may have a couple out of spec, but the difference is pretty minor. If you're a DIYer, it's a free improvement, but I don't know if i'd pay someone to do it.
I'm about to adjust mine again, but it's because my idle isn't as smooth as it used to be, and the valves are getting a little noisy again.
