When to Adjust Valve?
Old Mar 30, 2009 | 12:46 AM
  #31
S2K_2003's Avatar
I adjusted the valves on my 2003 at 47,000, i gauged all the gaps, everyone of them were a few thousands out of spec, can really tell a difference,
$150 for an hour worth of work!!! I think that is called RAPE LOL
Old Mar 30, 2009 | 08:52 AM
  #32
SquirtleS2K's Avatar
Hmmm..... Hmmm... *thinking* maybe I should get mine done -.- But thats money.... Hahaha... clutch first!
Old Mar 30, 2009 | 10:18 AM
  #33
slimjim43's Avatar
Originally Posted by jeffbrig,Mar 27 2009, 07:35 PM
I'm about to adjust mine again, but it's because my idle isn't as smooth as it used to be, and the valves are getting a little noisy again.
When you say, valve is getting noisy, you mean at idle, you hear a ticking sound?
I' am a DIY person, after reading the DIY instruction, doesn't seem like hard at all.
Will probably do this summer.
Old Mar 30, 2009 | 11:02 AM
  #34
Random1's Avatar
When some of you quote say "out of spec" what exactly do you mean? Is it tight or loose from the nominal value (middle of range) or is it out of the specified range?
I do a valve check/adjustment once per year (~20-25k). For my MY00 that had 115k when I sold it the valve cover gasket was never replaced and it never leaked or had a problem.
I just did my MY03 with 27k when I bought it and found four valves tight from the nominal (center of spec) value. Tight means I could not get the feeler guage into the gap to allow measurement. These four were adjusted to the nominal value.
Backmarker
Apr 12, 2016 06:31 AM
Wojofoo
Sep 30, 2015 04:50 AM
Avionics86
Feb 13, 2007 07:13 PM
E36Ap1
Oct 20, 2004 08:29 PM
J.T
Jun 24, 2003 05:58 AM
