Where do I buy these washers?
Old Jul 24, 2010 | 09:37 AM
Ronss2k's Avatar
Default Where do I buy these washers?
I'm planning to change my transmission fluid, differential fluid and oil this weekend. From all the diy guides i've been reading they recommend changing the washers and replacing it with a new one. Where do I get washers for the bolts? I called my local Honda and they don't have it. Thanks for the help in advance.
Old Jul 24, 2010 | 09:46 AM
s2k aok's Avatar
honda doesn't have it? that is definitely unusual. i can't remember, i think i got mine from hardtopguy a long time ago. they recommend changing them but it's not necessary (although justifiably advised). it's just another item to nickel/dime you for by the service/parts department.
Old Jul 24, 2010 | 09:58 AM
Stratocaster's Avatar
The oil pan and transmission drain washers are the same and all Honda dealers stock it. It fits on all other Honda models. The diff and transmission fill washers however are only used on the S2000, so they don't stock them, so you will have to have them order them. They can be reused but some times you can have a small leak if you don't replace it. They are cheap so replace them if you can. I always do.
Old Jul 24, 2010 | 10:01 AM
ChefJ's Avatar
www.majestichonda.com
Old Jul 24, 2010 | 10:11 PM
Suzuka_Joe's Avatar
i've never changed the washers on the diff or tranny. i will next time
Old Jul 25, 2010 | 01:28 PM
civichx97's Avatar
I got the oil washers from the Honda dealer and they ordered the ones for the tranny and diff, they came in in about 2 days and it was a couple of cents for them..... just have your dealer order them in for you.
Old Jul 25, 2010 | 02:18 PM
pd0019's Avatar
arent the oil pan and transmission washers different? transmission washer is larger than the transmission washer.
Old Jul 25, 2010 | 02:45 PM
Gloffer's Avatar
The drain plugs are the same, the fill plug for the tranny has a larger diameter.
Tim S2K
Mar 7, 2008 03:43 PM
SlipAngle79
Jun 26, 2007 06:47 AM
s2k_suprchrgd
Jul 9, 2005 12:29 PM
ralper
Aug 1, 2004 12:15 PM
NFRs2000NYC
Apr 12, 2004 01:39 PM
