Where is the Tach Signal?
Old Apr 11, 2005 | 11:37 PM
jarod's Avatar
Default Where is the Tach Signal?
I'll be getting my car dyno'd this weekend and the dyno owners are asking in advance if I know where the tach signal to save them the trouble of having to find it/out.
Old Apr 12, 2005 | 03:34 AM
hondamanwill's Avatar
Connector Terminal
1: none
2: BLU (Tachometer signal)
53. Test Tachometer Connector
Old Apr 12, 2005 | 04:16 AM
Slows2k's Avatar
The Blue RPM output lead won't work with the Dyno's pickup.
Remove the coil cover, and put the pickup around the wiring to #1 ignition coil.
Old Apr 12, 2005 | 07:31 AM
Elistan's Avatar
Also, making sure the three wires that Slows2k mentioned are flat and in a row will often solve issues with weird signal pickups, I've found.
Old Apr 12, 2005 | 09:13 AM
jarod's Avatar
Thanks for the replies. I have no clue what you all are talking about but I'll forward this thread to them.
Old Apr 12, 2005 | 11:54 AM
ultimate lurker's Avatar
No need to remove anything. Just behind the intake manifold by the firewall is a small loop of plastic sheathed wire. The loop has a stripe of white tape on it. Your ignition pickup should go here for a #1 cylinder spark signal. This is the same lead we use to do ignition timing calibration.
UL
Old Apr 12, 2005 | 02:49 PM
Slows2k's Avatar
Good tip UL, Thanks!
jelanier
Mar 7, 2014 05:37 AM
geared
Aug 25, 2012 05:49 PM
yyyiiikes
May 23, 2008 11:03 AM
S2tripleO
Feb 18, 2006 09:38 AM
Silver S2k Guy
Jun 11, 2001 07:55 AM
