Whistle while it works (runs)
Old May 21, 2017 | 05:08 PM
AZS2KDancer's Avatar
Default Whistle while it works (runs)
I hear a distinct high pitch whistle while accelerating and decelerating. Yet it goes away when the clutch pedal is fully depressed. Any idea what is causing this, and how to correct it?
Old May 21, 2017 | 05:31 PM
Hfreak's Avatar
CAI by chance?
Old May 21, 2017 | 06:02 PM
No CAI; stock air intake. Only change was to swap out the TCT to a Billman250 Gen X TCT last year.
Old May 22, 2017 | 07:16 AM
Car Analogy's Avatar
Is it possible its more of a whine than a whistle, as in diff or trans whine?
Old May 22, 2017 | 12:40 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Must be your blow-off valve.
Old May 22, 2017 | 09:51 PM
I don't mind turning a wrench, yet I'm not familiar with a blow-off valve. Is that the official name in the Service Manual? Where do I find this shrill whistler? It's not a whine, it's a whistle that rises with RPM and lowers as RPM falls. High pitch and shrill.
Old May 23, 2017 | 06:36 AM
HaHa! A blow off valve is a mod used with some turbos. We obviously don't have one (unless your S is heavily modded). It allows excess boost to blow off, and makes a sort of whoosh sound when it does.
If its truely a whistle, and it goes with rpm, its some sort of air leak. Probably on the intake side (exhaust side would be a different sound).
Suspects would include anything rubber, intake hose, vacuum hoses, etc. Also anyplace in intake there is a gasket. TB, IM, etc. Also the pcv valve. You get the idea...
pinstriped06
Feb 2, 2010 08:29 PM
SIIK2NR
Oct 11, 2005 07:45 AM
S2k001
Jul 21, 2003 05:28 AM
greeny488
Aug 27, 2002 01:46 PM
BlueS2000Boy
Jul 5, 2002 06:58 PM
