White smoke from exhaust
Old 12-14-2016, 12:43 PM
S2kJoshh's Avatar
Default White smoke from exhaust
I have read a lot of other posts and have not come to an answer yet. This is my situation, may be a little different.
Setup:
120k miles, 00' AP1, Berk high flow cats, HKS exhaust (dual exit) and cold air intake
I get white smoke coming out of my exhaust tips when the car is at higher RPMs. When I am cruising and not flooring it, keeping it low, there is no white smoke coming out. I have had a few people tell me when I am pushing it at high RPMs, white smoke is coming out and when I sit idle and rev it up high.
Coolant and oil seem fine
Thank guys!
Old 12-14-2016, 01:15 PM
windhund116's Avatar
Received 1,443 Likes on 967 Posts
Maybe coolant leak in head gasket. Run a head gasket coolant pressure test. Good luck!
Old 12-14-2016, 05:27 PM
zeroptzero's Avatar
Received 3,390 Likes on 2,461 Posts
Gasket leaks are very rare unless you have overheated the engine, or it is running boost.
I've said it before that whitish smoke when running HFC's or test pipes can occur as it is a mix of moisture, fuel, and oil. Mine has done that before, after switching to the OEM cat it did not happen again as OEM cats are three-way catalysts that convert hydrocarbons, HFC's are not three way. Seen it on a few S2000's that did not have coolant leaks,including mine. If you have a coolant leak on a car it is very evident and you will smell it.
sapone
09-26-2011 10:45 PM
s2cho
09-21-2011 02:11 PM
dibi
11-24-2009 07:10 PM
fadiss2k
07-17-2007 06:25 PM
S2SEXY
10-28-2005 08:46 AM
Quick Reply: White smoke from exhaust
