White splatter on injector & intake manifold
Old Nov 15, 2004 | 04:12 PM
OnlyInRio's Avatar
Default White splatter on injector & intake manifold
I'm going to be getting into an S2000 real soon and currently doing my research. I looked at a brand new Suzuka Blue S2000 at the dealership I work for and noticed white splatter on top of the engine. What is the part with the plastic top that sits in the injector rail cover? It has a white coating around it and appears that due to heat it had become liquid and splattered on the intake manifold, injector rail cover and the small hose nearby.
Old Nov 15, 2004 | 05:21 PM
Slows2k's Avatar
It's a dry leak check spray applied at the plant. All S2k's have it, your pic shows a little more applied than others.
The part in question is the fuel rail pulsation damper, which holds the fuel line to the rail.
Old Nov 15, 2004 | 08:56 PM
OnlyInRio's Avatar
Thanks for your answer and description of the part. I had a feeling it was some type of spray to check leakage of the part but not wiped off. Just odd that Honda would leave it like that. Quite noticeable when you open the hood.
B0neSt0ck
Mar 3, 2014 09:03 PM
FitzyS2k
May 14, 2008 07:11 AM
bluesaint
Jul 12, 2006 06:34 PM
Sideways
Mar 5, 2004 06:49 PM
