wierd sound under throttle!
Old Jan 31, 2008 | 11:10 AM
fadiss2k's Avatar
Doesnt get louder if i turn one way or the other.
Old Jan 31, 2008 | 11:20 AM
PrecisionS2K's Avatar
then it's most likely the driveshaft. also, if you completely removed the driveshaft to replace the clutch you may have installed it in the wrong position. sometimes if a driveshaft isn't put back in exactly the same way it came out, it can make a noise like what you're hearing.
Old Jan 31, 2008 | 05:44 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I purposely put s2k driveshafts back in the wrong position (markings not aligned) to prove a point
No way your noise is from an "out of phase" driveshaft.
Old Jan 31, 2008 | 09:50 PM
fadiss2k's Avatar
no, i didnt think putting it on the wrong way mattered for noise. I had a problem with my propeller shaft about 2 years ago. It was making a noise similar to this, but i dont think it mattered if the clutch was engaged or not. Oh well, i guess ill just have to start replacing things and see what it is bc im stumped and hate taking the car to honda!!!
Old Jan 31, 2008 | 11:57 PM
jyeung528's Avatar
when you guys say driveshaft, do you mean the propellar shaft, or the half-shafts going to the wheels?
could be prop shaft or clutch installation error or transmission linkages....up to you to diagnose, seems like you've had quite a bit of work done to the drivetrain.
Old Feb 1, 2008 | 11:49 AM
IlleztImportz's Avatar
man that sounds bad, mine doesnt sound that bad but a little similar. i guess im going to swap out my prop. shaft and see what that does
Old Feb 1, 2008 | 06:16 PM
J'sS2K's Avatar
Does this sound like this?
http://youtube.com/watch?v=PMpUKWb5zz4&feature=related
Jason
Old Feb 1, 2008 | 07:13 PM
fadiss2k's Avatar
YEP!!! thats what it sounds like! What is it?
Old Feb 2, 2008 | 01:30 AM
Ahnold's Avatar
Sounds like an exhaust leak. An out of phase driveshaft shouldn't make any noise, just vibration.
Old Feb 2, 2008 | 02:13 AM
dievoche's Avatar
it cant be too bad. a noise that loud on anything with a serious load would have died by now. then again it could be on its way out. ive no flippin clue. BUT. my kia sephia was makin the same noise a couple weeks ago. ended up being the ac clutch was sticking . but im intereseted to see how this turns out. ill run this by my pop (my mechanic) see what he thinks. hes not wrong too often
