Wiring Harness Help
Old Nov 24, 2011 | 05:10 PM
_Kyo's Avatar
Default Wiring Harness Help
the wiring harness on the firewall near the battery of my car is damaged. i discovered a small section of the insulation is gone and a few of the wires were severed. the damaged section is about 1cm long. does the entire engine harness need to be replaced?
Old Nov 24, 2011 | 05:46 PM
Stratocaster's Avatar
You need to replace the right side engine bay harness. It is a PIA but not as bad as doing the dash harnesses.
Old Nov 24, 2011 | 07:06 PM
_Kyo's Avatar
shiit.. how do i get it out of the firewall? is there a connection under the dash?
Old Nov 24, 2011 | 09:44 PM
_Kyo's Avatar
i ended up splicing the severed wires.
Old Nov 25, 2011 | 04:09 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
just repair it with solder and shrink wrap.
If you dont solder the wires, I promise you the connections will fail. the corrosion from a bad connection will also travel its way through the harness.
Very fixable if done right.
Old Nov 25, 2011 | 08:50 AM
SgtB's Avatar
Make sure you use water proof / marine grade shrink wrap too. It has a gel layer inside that melts into all the voids and solidifies once it changes state.
Pinky
Dec 14, 2014 09:18 PM
turbo8765
Nov 12, 2011 08:55 AM
dres2k
Nov 29, 2008 02:38 PM
doctornick
May 16, 2007 04:30 PM
emrillive
Dec 16, 2004 03:03 PM
