Wiring up the Yellow Box
Old Mar 10, 2003 | 01:49 AM
Rick Hesel's Avatar
Former Sponsor
Default Wiring up the Yellow Box
In anticipation of the 4.44 rear gear set install, I've obtained a Yellow Box and am trying to figure out the easiest way of wiring it into the speedo connections. The Helm manual is not much help.
My best guess would be to tap in where the wires come out of the connector to the sensor on the transmission case. But knowing that others have already done this, I thought I might save myself some agony by asking first.
Old Mar 10, 2003 | 02:54 AM
Sideways's Avatar
I tapped in next to the ECU. No long wires.
Old Mar 10, 2003 | 07:54 AM
BryanS2k's Avatar
To tell the truth guys I believe all that is needed is a resistor because the speedo is basically a voltage meter. So if someone was to find out the correct type of resistor then I believe people wouldn't need this yellow box stuff and anymore wiring other then slicing a single wiring and placing a resistor between the ends... Has anyone taken apart of a "yellow box" before?
bryan
Old Mar 10, 2003 | 08:02 AM
Gernby's Avatar
Former Sponsor
bryan
That is not how it works at all. The speed sensor sends pulses. The yellow box is a pulse divider. For instance, at 60 MPH, the speed sensor may put out 10K pulses per second. The yellow box allows incremental changes, via dip switches, to correct that to 9XXX pules per second.
Old Mar 10, 2003 | 09:09 AM
xviper's Avatar
Rick, if you search for "jenner" and "yellow box", you will find instructions on which wire near the ECU to splice into. On my car (with DRL's), jenner's instructions will not work so I spliced into the actual speedo wire off the tranny case and ran the twin wires up toward the motor and through the firewall. The other two wires are simply hot and ground. My Yellow Box lives just inside the kick panel.
Old Mar 10, 2003 | 10:09 AM
turbo_pwr's Avatar
https://www.s2ki.com/forums/showthread.php?...?threadid=74688
Old Mar 10, 2003 | 10:23 AM
vapors2k's Avatar
i installed mine at the sensor by the tranny. The unit is pretty sealed up and protected. It's all the same, I found it easier to install there since all the wires you need are there.
Old Mar 10, 2003 | 02:42 PM
Rick Hesel's Avatar
Former Sponsor
Thanks for all the great information and advice
Old Mar 10, 2003 | 05:26 PM
BryanS2k's Avatar
ahhh Ic.
bryan
Old Mar 13, 2003 | 08:20 AM
Jenner's Avatar
Rick how did you make out?
Stecu
Apr 25, 2017 05:44 AM
le do
Mar 18, 2016 02:34 AM
macr88
Drivetrain
Jan 18, 2010 12:43 AM
lil dog
May 14, 2008 12:15 AM
radtech
Nov 11, 2006 07:27 AM
