Advice needed- difficult to shift
Old May 23, 2012 | 09:04 AM
  #71
MsPerky's Avatar
Community Influencer
That would be a long drive! Hope to see you. If flying is an option, Winchester is only about an hour from Dulles Airport.
Old Mar 2, 2014 | 06:09 PM
  #72
brownieap1's Avatar
I have similar problems. 01ap1 113,900 miles. Changed clutch fluid. Bled the clutch, changed the Trans fluid about 5 months ago. I use synchromesh . Going to change it in about a week with Hondamtf.. No leaks on my CMC or slave. Anyways, I can't get it to downshift for example into 2nd at like 25 mph as well as any other gear. Also when high revving it also won't go into gear. Seems like it hesitates and I have the wait for the engine to rev down so to speak. I can shift fine through the gear on/off adjusted my pedal. Only thing left to do is re grease my shifter. You thing doing that alone with take my symptoms away.? Appreciate any feedback. I know of some posts similar to this but it ended up be a CMC or low fluid which is not my case.
Old Mar 3, 2014 | 12:15 PM
  #73
Legal Bill's Avatar
If there are no leaks, I must ask if you have adjusted the play in the clutch pedal? There is an adjusting nut on the shaft that operates the CMC. This shaft is attached to the clutch pedal arm. You get to if from inside the car.
Old Mar 3, 2014 | 03:48 PM
  #74
brownieap1's Avatar
No I haven't tried that. The play in the pedal feels about right to me. If I were to adjust that nut what would that resolve.? There is enough play where it's not stiff.. This all happen out of the blue by the way.
Old Mar 3, 2014 | 04:47 PM
  #75
brownieap1's Avatar
Tried posting a video of my ap1 one about 150-200 miles ago shifting fine through the gears but can't seem to figure it out
Old Mar 4, 2014 | 03:50 PM
  #76
brownieap1's Avatar
It's fixed. I have a leak on my Trans. Refilled it. Gonna see where it's coming from.
Old Mar 5, 2014 | 06:38 AM
  #77
dlq04's Avatar
Identify the cause is the key to finding a solution.
alexisthemovie
Dec 31, 2010 10:07 AM
S2KN05
May 3, 2010 11:55 AM
fadiss2k
Apr 25, 2009 04:51 AM
hondalegend
Sep 9, 2006 12:05 PM
jin6
Oct 13, 2005 06:31 AM
