Does Wax Expire?
Old Dec 20, 2006 | 12:16 PM
bucsdork99's Avatar
Default Does Wax Expire?
I wanted to give s100 a try so i went to a harley shop and found it. But on the package it had the date 8/30/05 stamped on it. Does this means the wax is expired?
Old Dec 20, 2006 | 01:16 PM
wanabe's Avatar
should still be o.k. if it has been kept sealed...
you can tell when you use it- wipe it on and wipe it off in a small area. you can feel the diff if its sticking (use the backs of your fingers)- feel the area that you did and the area that you didnt do...
also you might be able to see a bit of diff too.
the real way to tell is to put water on the areas and it will bead up nicely if the wax is good.
again, i would expect it to be fine
Old Dec 20, 2006 | 01:31 PM
NFRs2000NYC's Avatar
It doesnt really expire, but I have had a number of bottles....
a)dry out (turn into powder basically)
b)Separate (water/oil type thing)
If it is sealed, and keep indoors, you should be fine.
If you have a bottle that is sitting long enough, you arent waxing your car enough!!!
Old Dec 20, 2006 | 03:03 PM
S2kMarkus's Avatar
itll be ok, im on the same can of s100 for about 2 years now.
Old Dec 20, 2006 | 03:16 PM
bucsdork99's Avatar
thx for the responses! i guess i'll go back and get some.
Old Dec 21, 2006 | 12:11 PM
Ajserrano's Avatar
I had a bottle of Gold Class saparate(b.). Should I throw it out or is it still usable?
Old Dec 21, 2006 | 12:33 PM
Still useable.....just shake the hell out of the bottle.
Old Dec 21, 2006 | 12:51 PM
Bass's Avatar
s100 should be fine as it's pure carnuba
other liquids and waxes will expire - heck i had a tin of two year old mothers gold that smelled like petroleum distillates
@loha
Jan 2, 2013 08:33 PM
clean_2001
Feb 17, 2010 04:11 AM
Oake
Oct 10, 2007 09:24 AM
GR33KWRX
Nov 4, 2005 06:51 PM
asdfg123hk
Jun 16, 2005 04:38 PM
