Engine Wash...?
Old Aug 21, 2014 | 06:59 PM
JulioOchoa23's Avatar
Default Engine Wash...?
Hey guys, my s2k's engine is kinda dirty.
Really only the intake manifold is. Kinda spotty and idk what it is.
I tried a spray specificlly made to clean the motor and nothing really cleaned up.
Any help?
I don't want to dress up my motor and have it all dirty :l
Old Aug 22, 2014 | 06:26 AM
TomSolo's Avatar
I use simple green on mine. I hose everything down, spray simple green and let it soak for a bit, scrub any parts that may be heavily soiled, then rinse it off. I use a leaf blower to blow any standing water out from places I cant reach with a towel. Once everything is dry I spray Black Magic on everything and give it a good wipe down. I'm sure there are different ways and products to use that may be better, this works for me without breaking the bank.
Old Aug 22, 2014 | 07:01 AM
DrakeValle's Avatar
There are some really good DIY's for cleaning the engine bay.
Also check out this guys thread. He used Chemical Guys degreaser.. really did a great job cleaning up the engine bay.
https://www.s2ki.com/s2000/topic/109...works-whybshy/
Old Aug 26, 2014 | 06:59 PM
cosmomiller's Avatar
Top Answer: 1
Once you get it clean, its easy to keep it that way. This has been the easiest car ever to keep the engine compartment clean. I wipe it down every time I wash the car. I use the microfiber cloth I just used to dry the car with. Its damp and perfect for wiping away any dust.
Old Aug 28, 2014 | 02:00 PM
Feezy's Avatar
Both of my S2000's have color imperfections on the intake manifolds in different places. I think it's just the way they are cast.
If you can post a picture of what you don't like we'll be able to better help you.
Old Oct 24, 2014 | 06:06 AM
luckybamboo's Avatar
been looking to refresh my guy under the hood but wondering if it is safe to do so.. @TomSolo, what precautions do you take before you spray things down under the hood? some pics or even a video would be truly grateful.
side note, is there a way to get super caked on brake dust off rims (silver ssr type c's)? every time i wash my car i feel as if i did a crappy job.
Old Oct 24, 2014 | 09:53 AM
solitarycheese's Avatar
On a cold or warmish engine (never hot! with the hood open and a fan running on it, it takes about 40 minutes for the block temperature to drop from 200* to 120*) I cover the battery, fuse box, and alternator with plastic bags, then mist the engine bay with a 1/20 dish soap/water solution. Agitate with a soft brush on the areas that need it. Then a light spray with the hose to rinse. Blot up as much water as you can with rags. Then spray with 303 or other dressing and let it sit for ~10 min. Wipe clean again, and run the engine with the hood closed for the final dry (don't forget about the plastic!).
Check out page 4: http://home.comcast.net/~michael.coh..._Hand_Book.pdf
Vinny_GPW-S2K
Apr 15, 2012 06:46 AM
SOL1D
Apr 2, 2011 09:34 PM
NFRs2000NYC
Sep 10, 2008 09:15 PM
s2kinfinite
Jun 4, 2007 08:09 PM
Mok
Jul 23, 2004 11:54 AM
