Scratches in side view mirrors
Old Oct 26, 2008 | 06:36 PM
akimel's Avatar
Default Scratches in side view mirrors
Our S2K side view mirrors are plastic, right? I've got some scratches in mine. Why do you suggest I use to try to remove or minimize them? TIA.
Al
Old Oct 26, 2008 | 06:40 PM
wanabe's Avatar
i assume that you mean the outside shell- right?
if so, you would use the same polish that you use on the paint, cause thats what it is!!
it is clearcoated paint...
how bad are the scratches?
i like menzerna polishes for light scratch and swirls remover- if you can see a color other than black in the scratch, its more than just a polish solution... those require added repair steps.
Old Oct 26, 2008 | 06:49 PM
akimel's Avatar
Yes, I am referring to the outside shell.
I have a couple of scratches that I can catch with my finger nail. The others are not as deep.
I have a tube of ScratchX. I guess I should try that and see if it helps. I was afraid to try it on the plastic. Thanks.
Old Oct 26, 2008 | 07:07 PM
Panopticon's Avatar
If you can run your fingernail along the scratch you are not going to be able to remove it.
Old Oct 26, 2008 | 07:49 PM
akimel's Avatar
Yes, I understand that. But I'd like to see if I can eliminate the other scratches or at least minimize their visibility.
Old Oct 26, 2008 | 09:07 PM
G's Avatar
G
You can try the scratch x, I have never used it, so I have no input on how it might work for you.
I do agree with above that if you can feel it with your nail, it is too deep. In that situation, your goal should be to soften it and reduce it's noticablility.
Old Oct 26, 2008 | 09:24 PM
Panopticon's Avatar
You can try ScratchX but I doubt it will do much good if you have serious scratches. Do you have pictures of the problem area? I agree with Wanabe that Menzerna polishes are top notch.
silenc3x
Jul 27, 2018 05:51 PM
slanguage
Jun 30, 2007 07:31 AM
Shipley
Apr 7, 2006 08:08 AM
Congo
Dec 8, 2005 05:58 AM
nMeOnE
Sep 2, 2004 03:30 AM
